Why is my Y axis moving in opposite direction?
kencnc411
kencnc411
Upgrade to Leadshine DMA860H stepper drivers now my Y axis is moving in the directions. I m using Stepperonline 23HS45-4204S motors.
My wiring is as follows
Nema motor Black to A+ on DMA860H
Nema motor Green to A- on DMA860H
Nema motor Red to B+ on DMA860H
Nema motor Blue to B- on DMA860H
Basso S+ to DMA860H Pull+
Masso S- to DMA860H Pull-
Masso D+ to DMA860H Dir+
Masso D- to DMA860H Dir-
Hi @kencnc411
The direction the motor runs is dependent on settings in Masso and the wiring of your motors and drivers.
Personally I would make my wiring all the same and invert the axis direction in Masso.
In Masso on the Y Axis put a check in or remove the invert direction as appropriate.
kencnc411
kencnc411
Odd thing is, tonight I turned the Masso on and the YAxis is no longer inverted. I have not made any changes wiring or settings.
