johnharvey
johnharvey
So I while doing my machine retrofit the MASSO WIFI antenna was measured at 25' from the router line of sight, no obstructions and it was able to connect and transfer files reliably. Now that I have moved the machine into position at 50' away, twice the distance, and still line of sight with no obstructions, I am unable to get a connection established??? My MASSO antenna is externally mounted.
What is the expected range?? What can I do to get it reconnected? Every other device in the shop has no issues with connectivity. The new build 3.44 did not help.
Thanks,
John
Thanks,
John
