segoman-designs
SegoMan DeSigns
Here is some links and how too s for those of you who have the external wifi antenna and need to put the antenna outside of the enclosure.
The OEM set up only has about 6" of cable, I needed 1 meter to get the antenna to the top / outside of my cabinet.
I found this via a search on the "ESP 07S" chip
The chip requires a U.FL end and the antenna bulk-head fitting requires a RP-SMA end
1 & 2 meter cables here
www.data-alliance.net
Bulk-head fitting here (This requires a 5/16" hole) the inside is for the cable / outside for the antenna (OEM or otherwise):
If you require a right angle for cable routing:
Longer antenna with a 12 db gain here (I call it the whopper)
Ask away with any questions..
U.FL To RP-SMA-male Cable: 3FT, 6FT Double-Shielded Outdoor Indoor
One end has a U.FL connector, and the other end has an RP-SMA-male connector. Double-shielded cable design leads to low signal loss and reduced interference.
Adapter SMA Female To SMA Female: Waterproof O-Ring Bulkhead Coupling
One side has a large-sized bulkhead nut, much larger than the standard SMA bulkhead. Equipped with red O-ring for a waterproof seal, with an IP68 rating.
SMA Right Angle male To SMA-Female Adapter
Broad frequency band compatibility from 0GHz to 18GHz, with a consistently low broadband VSWR, and 50-Ohm impedance matching. Supports 802.11ac/n/g/b/a.
Antenna 2.4GHz 12dBi Omni Directional Dipole w/ RP-SMA | 22 inches
Omni directional antenna with RP-SMA-male connector for Wi-Fi, Bluetooth, wireless networks. Compatible with access points & cards using RP-SMA antenna jacks.
