Wireless MPG
ezzupturbo
Ezzupturbo
If you want a wireless style pendant something like this should work. Note you will need to add a vreg to the receiver and maybe an estop if you want one on the pendant.
I have just ordered one to see how it goes. Will let you know when I receive it
Well spotted, that looks very interesting and seems like it might work. As you said it will need a 5 volt regulator or a separate 5 volt supply with a common ground
A pity it doesn't have an EStop button but you might be able to add a button across the 5th axis switch or simply turn the knob to the 5th Axis position to activate EStop.
Looking forward to seeing how it goes for you. Maybe a wireless MPG will be possible.
x-cnc
X - CNC
Quote from Ezzupturbo on January 6, 2019, 1:40 am
Very interested in how this works. Please update with your results.
One of the biggest disappointments with the Masso is that it doesn't support common USB devices for add-ons. Not even USB 2.0 devices. Hopefully this wireless pendant will be an exception, even if it is a bit pricey with a lack of features.
Quote from MASSO Support on January 6, 2019, 5:23 am
They do make a version that has the e-stop included. It cost $355.00, and e-stop is the only difference between the two. A little pricey for one more feature.
ezzupturbo
Ezzupturbo
Wireless mpg worked perfect no issues at all even added a estop. Just had to wire it all to the dB connector.
Might take a video later.
