Jordi
Member
Hello again. I'm trying to figure out how to install two AMB 1400 FME-P DI milling machines in a multihead system. I have read the section on the website, I understand the connection through solenoid valves that will lower and raise cylinders... I understand that. Okay,
When activating the spindle, it only shows an example of a connection with a frequency converter with two UVW spindles. But it is not my valid connection type since it will not use vfd.
In my case I will have 2 AMB1400 FME-PDI 230V milling machines :
CNC-router connection (three-core)
brown: 10 - 26 V DC for power supply
green; 0 - 10 V DC for speed control
white: 0 V for ground/ GND
I see In MASSO "SPINDLE CONTROL" outputs that "output 1 "corresponds to the 0-10V control ,and "output 2" corresponds to spindle activation Forward ( 24v are powered through the masso relay on activation)
This connection would be great if I only had one spindle, but I have 2!
Reading the documentation again shows:
"The output also directs the Spindle control to the required spindle. This can be done using 2 methods.
1 The Spindle control signals Speed, Forward & Reverse could be switched to the designated Spindle and each spindle would have it's own dedicated VFD.
2 The Machine has one VFD and the 3 Phase power is switched to the selected Spindle using a 3 Phase contactor relay unit."
Type 2 is the one shown in the example, which I have already explained is not my case.
Maybe type 1 will work for me, but I have no idea how to make that "switch" change to connect "SPEED 0-10V" and "Forward" in each spindle in addition to also having the coils connected for using with multi-head.
Can someone help me with some instructions to connect 2 AMB machines in multi-head. Thanks in advance.
