What I am asking is probably very simple, but I am afraid I might damage the hardware if I do it wrong, so any advice would be greatly appreciated.
In the MASSO documentation, I found a wiring diagram for the specific drive I intend to use, unfortunately, it doesn't show how to connect the Pin2 (ABS_H) for triggering the drive absolute homing function. It is rarely used but this is exactly what I need for my setup.
So basically what I am trying to find out is:
I am attaching the diagram and some screenshots from the manual. The DYN4 whole manual could be found here - Link
- How to wire Pin2 (DYN4) to the MASSO controller so it receives a signal with proper length, voltage, and amperage?
- How to set the Output in the MASSO software?
- Would it be possible to control this function from the MASSO interface?
