Wiring Omron E2B-M12KS04-M1-B1 Proximity sensors
perry
perry
I'm having a bit of a brain fart at the moment. hopefully someone sees this and can quickly tell me how to connect this to my Masso. I don't want to risk blowing anything by doing it wrong.
This is the wiring diagram for the homing sensors I bought https://www.mouser.com/ProductDetail/653-E2BM12KS04M1B1 --
Am I correct that +24VDC goes to the Brown. Ground to the blue wire, and the signal is on the black?
Thanks!
Hi @perry
yup that's pretty well standard for prox wiring if you are using sinking inputs, which I do believe is compatible with Masso. The input will go high when energized.
Edit Blue wire goes to -24v terminal actually, not ground just to clarify that.
perry
perry
Great - thanks. I was able to get them all wired up and tested. About to run the control box down to the basement to hang it on the wall and wire up the sensors.
haris44-hagmail-com
Haris Abdullah
Hi @perry
Iam having same sensor except its a npn type. But when i connected to masso as per diagram it triggered high and when i trigerd sensor it doesnt change the signal. What to do. And before that i was using other sensor it work properly. I check with multimeter it show 1 when it trigerd it show higher than 1 what to do
Haris,
Go through attached doc it will solve your problem
regards,
  • Masso-Quick-start-Guide-Homing-switches-Google-Docs.pdf
