Wiring the new (4-wire) homing sensor
kencnc411
kencnc411
Where does the black wire go?
Connections
  • BROWN (9~24VDC)
  • BLUE (0V)
  • BLACK (NO Normally Open)
  • WHITE (NC Normally Connected)
@kencnc411
It depends on how you want to setup your homing inputs. You only need to use one or the other. Usually the NC contact is used as any break in the circuit will trip the MASSO homing / overrun logic. Using the NO contact won't protect you against opens in the circuit.
