mtlchsr
Mtlchsr
Still converting the Vertigo MX2 to Masso G3....... I cannot find in all the Q&A as well as documentation something a bit specific about getting actual router motor connected to Masso. Most info deals with VFD spindles. By this I mean getting a relay sorted to activate the spindle. I have a simple 240volt Makita router as the spindle with a relay to do something already existing in the MX2 frame (e-stop cutout maybe ) It (the Makita spindle) was always manually switched on and manually speed controlled. That is.. the Makita was seperately plugged into the wall socket (240V ac) and then manually switched on at the motor when you were about to start a job. The Makita unit has a rpm control button on the unit. The e-stop on original controller would stop the makita if activated.
My question is this, I know the 2 wires that go to the relay.... what do I do with them... do they both go to the 'Spindle Control' connector, if so what pins? I only need the same scenario with the conversion - or can Masso get the spindle to start/stop with start/stop of job... i.e. activate the relay to accomplish this (if I leave the switch on the unit on)
Is there a documentation page telling us what the orange pins do ?
Photo of relay box attached if that is any help in the equation.. (maybe it is not a relay at all but some other kind of electrickery ?)
