I'm running a 5 by 10 foot plasma table with a slave on the x axis running one side of the gantry. I'm having a strange issue where I'm cutting a straight 150mm curve in the y direction so no input on the x direction, and the slave axis rotates the stepper about 1/4 of a turn or about 3 mm linear with my gearing in the positive direction. The slave is the drive moving, no movement in the actual X axis drive. I'm going to wire the slave directly into the other output like I've read on here and make sure I'm not getting some type of feedback in the system.
Any help would be appreciated
