G'day,
I'm running into a problem with this post, The post runs fine until it gets to "T12M6" the machine moves to the tool change position that I have designated fine, however after I have change out tool 7 for tool 12, instead of moving to the auto tool zero touch plate the Z axis runs up and hits the limit switch, I have checked the post and can't see any reason why it does this, the previous two tool changes work perfectly.
:- post,
G00Z5.0800
M5
(Change to Tool: End Mill {0.25 inch})
T12M6
S12000M03
(Toolpath: External Profile 2 Tool: End Mill {0.25 inch})
G00X-3.1750Y0.0000Z5.0800
G1Z-3.0000F762.0
G1Y270.0000F2540.0
Note:- Tool 7 and Tool 12 both have offsets in the tool list even though I am using a zeroing plate, could this be the problem?
2nd Note:- I know my X value is in the negative, however I back off from my homing switches 5mm and have set my minimum travel values to -5mm this allows me to locate my stock against a fence at X0 Y0 and reduce waste.
I have attached the post for you to look at, I can't find anything wrong with it maybe you can.
Thanks,
Lyndon.
:- post,
G00Z5.0800
M5
T12M6
S12000M03
G1Z-3.0000F762.0
G1Y270.0000F2540.0
Thanks,
Lyndon.
