Hi All,
Just wanting to see if anyone would have some advice to help solve a problem i am having with loosing steps on the Z Axis.
I am in the finals stages of a TEKCEL Router conversion. I have kept the original Pittman Servo motors, I have installed the MACHDRIVE Servo Driver boards & MASSO G3 controller. I have Tuned the servos, The motion of the machine seems good, I have just started the first couple of Cutting projects. During the cutting sequence, I am losing Step count and by the end of the cutting project the Z zero changes from being at the top of the cutting material, to approx 2mm above. This is over approx 5 min cutting file.
I have checked the following:
I am at a loss as to the cause of the variation, i am leaning towards that it could be potential Noise from the VFD but not sure how to test and would like to hear from anyone that has had a similar issue and resolved it, open to suggestions.
Regards
Damien.
- Checked the Drive Pulley (Belt drive) on the Servo Motor and it is tight, no chance of movement,
- Checked the Drive Pulley on the Ball screw - it is tight also with no movement
- Ran the project multiple times - Same result
- Connected to the MACHDRIVE driver board to see the DRO, It does not show the error, stays consistent with the MASSO controller,
- Checked the Earthing circuit of the main components, all are tight,
- Possibly some Noise from the VFD coming through, Spindle power cable is shielded and earthed to the VSD chassis & not at the spindle.
- I have reviewed the Soft and Hard limits and dont think there is any issue with the set parameters. These should not be hit during the project,
- I have looked over the NC code, nothing seems a miss, using the same generic post processor as I use on my smaller machine, all works OK.
- I have reduced the acceleration, it was 100 mm/sec, now 50 mm/sec (Not sure what is the correct speed here) X & Y @ 100mm/sec seem to function well, will need to test further.
Regards
Damien.
