I am trying to work out why I am getting a z soft limit annunciation.
I am cutting two identical profiles that are sitting side by side on a single piece of 25mm MDF. The first profile successfully completes. The second profile gets to be almost completed, and then stops with a z soft limit annunciated.
I tried rehoming and running the file again. Same result.
I redid the .nc file to be just the second incomplete profile. Stopped at the same position. Same annunciation.
So I exported the profile from the CAD file (rhino) and did the profile again from that (.dxf). Same result. Same stoppage in the same position with the same annunciation.
So I redrew the file again in rhino, this time with a different origin, and exported it again, this time as a .dwg. Same result. Same stoppage, same annunciation.
So that is 3 different .nc files. All giving the same result.
I tried the first and last one I did with a gcode simulator and it went fine.
The first successful profile is identical to the second.
The constant is the work reference (Thanks Peter for the education) and of course the Masso.
Attached is the last .nc file I used, and the stoppage is line 1010.
Any suggestions?
Any suggestions?
