Zero A axis
triump
Triump
Hi there,
How can I zero the A axis?
I am using the A axis to rotate 360 degrees multiple times. When the job ends, I would like to reset the A axis value to zero at the start of tge bext run.
From MASSO software version 3.38 you can have offset values set for A & B axis in F4 screen or also use a G92 command for temporary work offset, for example if you want to make the current position of A as 0.00 then give command G92 A0
